hi linuxusers
I recently switch to Emacs editor
how to avoid ~ files creation
I used keybinds
open file - ctrl + x + f
save file - ctrl + x + s
close file - ctrl + x + c
hi linuxusers
I used keybinds
Using following lines in the init.el will provide you the expected behavior
;; No autoback up and lock files
(setq
make-backup-files nil
auto-save-default nil
create-lockfiles nil)
checkout my config: https://github.com/ThangaAyyanar/Learning-Adventure/blob/master/Emacs/emacs_part8.org
Emacs playlist: https://www.youtube.com/playlist?list=PL0vwHm0AGyYP8yg0DZc8ApOEI7mw75U70
The emacs part 2 video contains the basic behavior & configuration changes
ok brother
thanks ![]()
