Git issue
my ssh token expired. when i created a new token i couldnt be able to connect with it. kindly give a step by step solution. that will be useful for the future, i have added the screenshot
you have messed the git remote.
you added your token in the remote origin name.
it should be like this
git remote set-url origin git@github.com:your-username/your-repo.git
remove the .git folder.
it will delete all the git repo references.
then start from beginning.
https://rogerdudler.github.io/git-guide/
delete the token on github as it is shared here in public.
create new token and use it.
