It acts like a man command, making tools easy to understand and use for anyone. This includes plenty of example commands, detailed explanations of how each one works, and fully documented instructions.
How it helps you:
The glc command provides usage instructions, installation steps, and examples — even when man pages are not available. It’s a quick reference guide right in your terminal.
glcshows usage instructions in English.tlcshows usage instructions in Tamil.
The first stage of usage instruction information has been added.
Source: 400 Linux commands
Happy to hear any ideas or modifications you have!
Note: This is the initial release. There may be a few typos in the code.
