I need to install linux mint 21 in my laptop iam including my system configaration pls guide to make partion i need to delete my existing partion and i need to create new one
description: Laptop
product: Latitude E5440 (Latitude E5440)
vendor: Dell Inc.
version: 01
serial: 3NQ0H12
width: 64 bits
capabilities: smbios-2.7 dmi-2.7 vsyscall32
configuration: administrator_password = disabled
boot = normal
chassis = laptop
frontpanel_password = disabled
keyboard_password = disabled
power-on_password = disabled
sku = Latitude E5440
uuid = 44454C4C-4E00-1051-8030-B3C04F483132
| id: | core |
| description: | Motherboard |
| product: | 08RCYC |
| vendor: | Dell Inc. |
| physical id: | 0 |
| version: | A00 |
| serial: | /3NQ0H12/CN1296347C017F/ |
| id: | firmware |
| description: | BIOS |
| physical id: | 0 |
| version: | A06 |
| date: | 05/01/2014 |
| size: | 64KiB |
| capacity: | 13MiB |
| capabilities: | pci pnp upgrade shadowing cdboot bootselect edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification netboot uefi |
description: CPU
product: Intel(R) Core™ i7-4600U CPU @ 2.10GHz
vendor: Intel Corp.
physical id: 42
bus info: cpu@0
version: Intel(R) Core™ i7-4600U CPU @ 2.10GHz
slot: SOCKET 0
capacity: 3300MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm epb tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid xsaveopt dtherm ida arat pln pts cpufreq
configuration: cores = 2
enabledcores = 2
threads = 4
| id: | cache:0 |
| description: | L1 cache |
| physical id: | 43 |
| slot: | CPU Internal L1 |
| size: | 128KiB |
| capacity: | 128KiB |
| capabilities: | internal write-back |
| configuration: | level = 1 |
| id: | cache:1 |
| description: | L2 cache |
| physical id: | 44 |
| slot: | CPU Internal L2 |
| size: | 512KiB |
| capacity: | 512KiB |
| capabilities: | internal write-back unified |
| configuration: | level = 2 |
| id: | cache:2 |
| description: | L3 cache |
| physical id: | 45 |
| slot: | CPU Internal L3 |
| size: | 4MiB |
| capacity: | 4MiB |
| configuration: | level = 3 |
| id: | memory |
| description: | System Memory |
| physical id: | 46 |
| slot: | System board or motherboard |
| size: | 16GiB |
| id: | bank:0 |
| description: | SODIMM DDR3 Synchronous 1600 MHz (0.6 ns) |
| product: | HMT41GS6AFR8A-PB |
| vendor: | Hynix/Hyundai |
| physical id: | 0 |
| serial: | E89C8382 |
| slot: | DIMM A |
| size: | 8GiB |
| width: | 64 bits |
| clock: | 1600MHz (0.6ns) |
| id: | bank:1 |
| physical id: | 1 |
| serial: | FC9CE382 |
| slot: | DIMM B |
| size: | 8GiB |
| width: | 64 bits |
| id: | pci |
| description: | Host bridge |
| product: | Haswell-ULT DRAM Controller |
| vendor: | Intel Corporation |
| physical id: | 100 |
| bus info: | pci@0000:00:00.0 |
| version: | 0b |
| width: | 32 bits |
| clock: | 33MHz |
| configuration: | driver = hsw_uncore |
| resources: | irq : 0 |
description: VGA compatible controller
product: Haswell-ULT Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver = i915
latency = 0
resources: irq : 45
memory : f6400000-f67fffff
memory : d0000000-dfffffff
ioport : f000(size=64)
description: Audio device
product: Haswell-ULT HD Audio Controller
physical id: 3
bus info: pci@0000:00:03.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver = snd_hda_intel
latency = 0
resources: irq : 49
memory : f7434000-f7437fff
description: USB controller
product: 8 Series USB xHCI HC
physical id: 14
bus info: pci@0000:00:14.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver = xhci_hcd
latency = 0
resources: irq : 42
memory : f7420000-f742ffff
product: xHCI Host Controller
vendor: Linux 4.4.0-21-generic xhci-hcd
physical id: 0
bus info: usb@3
logical name: usb3
version: 4.04
capabilities: usb-3.00
configuration: driver = hub
slots = 4
speed = 5000Mbit/s
physical id: 1
bus info: usb@2
logical name: usb2
version: 4.04
capabilities: usb-2.00
slots = 9
speed = 480Mbit/s
description: Mouse
product: USB OPTICAL MOUSE
vendor: YSPRINGTECH
physical id: 1
bus info: usb@2:1
version: 0.00
configuration: driver = usbhid
maxpower = 100mA
speed = 2Mbit/s
description: Communication controller
product: 8 Series HECI #0
physical id: 16
bus info: pci@0000:00:16.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver = mei_me
latency = 0
resources: irq : 46
memory : f743f000-f743f01f
description: Ethernet interface
product: Ethernet Connection I218-LM
physical id: 19
bus info: pci@0000:00:19.0
logical name: eno1
version: 04
serial: ec:f4:bb:50:94:0c
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation = on
broadcast = yes
driver = e1000e
driverversion = 3.2.6-k
firmware = 0.6-3
latency = 0
link = no
multicast = yes
port = twisted pair
resources: irq : 43
memory : f7400000-f741ffff
memory : f743c000-f743cfff
ioport : f080(size=32)
product: 8 Series HD Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 04
width: 64 bits
clock: 33MHz
latency = 0
resources: irq : 48
memory : f7430000-f7433fff
description: PCI bridge
product: 8 Series PCI Express Root Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: e4
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver = pcieport
resources: irq : 16
memory : f7300000-f73fffff
description: SD Host controller
product: SD/MMC Card Reader Controller
vendor: O2 Micro, Inc.
physical id: 0
bus info: pci@0000:01:00.0
version: 01
width: 32 bits
clock: 33MHz
configuration: driver = sdhci-pci
latency = 0
resources: irq : 16
memory : f7301000-f7301fff
memory : f7300000-f73007ff
product: 8 Series PCI Express Root Port 4
physical id: 1c.3
bus info: pci@0000:00:1c.3
version: e4
width: 32 bits
clock: 33MHz
resources: irq : 19
memory : f7200000-f72fffff
description: Wireless interface
product: Wireless 7260
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 73
serial: a0:a8:cd:92:7e:80
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast = yes
driver = iwlwifi
driverversion = 4.4.0-21-generic
firmware = 16.242414.0
ip = 192.168.29.165
latency = 0
link = yes
multicast = yes
wireless = IEEE 802.11abgn
resources: irq : 47
memory : f7200000-f7201fff
product: 8 Series PCI Express Root Port 5
physical id: 1c.4
bus info: pci@0000:00:1c.4
version: e4
width: 32 bits
clock: 33MHz
resources: irq : 16
ioport : e000(size=4096)
memory : f5000000-f60fffff
ioport : e0000000(size=301989888)
description: 3D controller
product: GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom
configuration: driver = nvidia
latency = 0
resources: irq : 50
memory : f5000000-f5ffffff
memory : e0000000-efffffff
memory : f0000000-f1ffffff
ioport : e000(size=128)
memory : f6000000-f607ffff
product: 8 Series PCI Express Root Port 6
physical id: 1c.5
bus info: pci@0000:00:1c.5
version: e4
width: 32 bits
clock: 33MHz
resources: irq : 16
ioport : d000(size=4096)
memory : f6800000-f71fffff
ioport : f2100000(size=10485760)
product: 8 Series USB EHCI #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver = ehci-pci
latency = 0
resources: irq : 21
memory : f743b000-f743b3ff
product: EHCI Host Controller
vendor: Linux 4.4.0-21-generic ehci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 4.04
slots = 2
speed = 480Mbit/s
description: USB hub
vendor: Intel Corp.
physical id: 1
bus info: usb@1:1
version: 0.04
slots = 8
speed = 480Mbit/s
description: Video
product: Laptop_Integrated_Webcam_HD
vendor: CN0767N97248745GBWK3A01
physical id: 6
bus info: usb@1:1.6
version: 42.14
configuration: driver = uvcvideo
maxpower = 500mA
speed = 480Mbit/s
product: USB 2.0 Hub
vendor: Standard Microsystems Corp.
physical id: 8
bus info: usb@1:1.8
version: 2.23
maxpower = 2mA
slots = 4
speed = 480Mbit/s
description: Generic USB device
product: VFS495 Fingerprint Reader
vendor: Validity Sensors, Inc.
physical id: 1
bus info: usb@1:1.8.1
version: 1.04
serial: 00a0b6b46294
capabilities: usb-1.10
configuration: maxpower = 100mA
speed = 12Mbit/s
product: Oz776 1.1 Hub
physical id: 4
bus info: usb@1:1.8.4
version: 1.10
maxpower = 2mA
slots = 4
speed = 12Mbit/s
| id: | usb |
| description: | Smart card reader |
| product: | O2Micro CCID SC Reader |
| vendor: | O2 |
| physical id: | 2 |
| bus info: | usb@1:1.8.4.2 |
| version: | 1.10 |
| capabilities: | usb-1.10 |
| configuration: | speed = 12Mbit/s |
description: ISA bridge
product: 8 Series LPC Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver = lpc_ich
latency = 0
resources: irq : 0
description: RAID bus controller
product: 82801 Mobile SATA Controller [RAID mode]
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 04
width: 32 bits
clock: 66MHz
capabilities: storage msi pm bus_master cap_list
configuration: driver = ahci
latency = 0
resources: irq : 44
ioport : f0d0(size=8)
ioport : f0c0(size=4)
ioport : f0b0(size=8)
ioport : f0a0(size=4)
ioport : f060(size=32)
memory : f743a000-f743a7ff
description: SMBus
product: 8 Series SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 04
width: 64 bits
clock: 33MHz
configuration: latency = 0
resources: memory : f7439000-f74390ff
ioport : f040(size=32)
| id: | scsi:0 |
| physical id: | 1 |
| logical name: | scsi1 |
| capabilities: | emulated |
description: ATA Disk
product: WDC WD5000LPVX-7
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/sda
version: 1A01
serial: WX21A54H6949
capabilities: partitioned partitioned:dos
configuration: ansiversion = 5
logicalsectorsize = 512
sectorsize = 4096
signature = 8369a5a5
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@1:0.0.0,1
logical name: /dev/sda1
logical name: /
version: 1.0
serial: fa87b53a-c6e5-4c68-9143-ce14f5f52b6b
capacity: 27GiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized
configuration: created = 2016-09-05 13:59:30
filesystem = ext4
lastmountpoint = /
modified = 2022-11-27 12:22:51
mount.fstype = ext4
mount.options = rw,relatime,errors=remount-ro,data=ordered
mounted = 2022-11-26 21:14:45
state = mounted
| id: | volume:1 |
| description: | Extended partition |
| physical id: | 2 |
| bus info: | scsi@1:0.0.0,2 |
| logical name: | /dev/sda2 |
| size: | 125GiB |
| capacity: | 125GiB |
| capabilities: | primary extended partitioned partitioned:extended |
description: Linux filesystem partition
physical id: 5
logical name: /dev/sda5
logical name: /home
capacity: 95GiB
configuration: mount.fstype = ext4
mount.options = rw,relatime,data=ordered
state = mounted
| id: | logicalvolume:1 |
| description: | Linux swap / Solaris partition |
| physical id: | 6 |
| logical name: | /dev/sda6 |
| capacity: | 30GiB |
| capabilities: | nofs |
vendor: Linux
physical id: 3
bus info: scsi@1:0.0.0,3
logical name: /dev/sda3
version: 1.0
serial: e97ba5c5-6a12-479c-a1e9-6c11e6a9530a
capacity: 146GiB
capabilities: primary journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized
configuration: created = 2016-09-09 13:34:34
filesystem = ext4
label = my bck
lastmountpoint = /media/anwar/my bck
modified = 2022-10-29 09:05:57
mounted = 2022-10-29 09:05:35
state = clean
vendor: Linux
physical id: 4
bus info: scsi@1:0.0.0,4
logical name: /dev/sda4
logical name: /media/anwar/my bck 2
version: 1.0
serial: 489db578-9241-42d1-845f-e2c619fb4083
capacity: 165GiB
capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created = 2016-09-09 13:35:38
filesystem = ext4
label = my bck 2
lastmountpoint = /media/anwar/my bck 2
modified = 2022-11-27 12:30:32
mount.fstype = ext4
mount.options = rw,nosuid,nodev,relatime,data=ordered
mounted = 2022-11-27 12:30:32
state = mounted
| id: | scsi:1 |
| physical id: | 2 |
| logical name: | scsi2 |
description: DVD-RAM writer
product: DVD±RW DU-8A5LH
vendor: PLDS
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
version: BD11
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
status = nodisc
| id: | battery |
| product: | DELL Y6KM747 |
| vendor: | LG |
| physical id: | 1 |
| version: | 07/01/2014 |
| serial: | 0C97 |
| slot: | Sys. Battery Bay |
| configuration: | voltage = 11.1V |
| id: | power |
| description: | To Be Filled By O.E.M. |
| product: | To Be Filled By O.E.M. |
| vendor: | To Be Filled By O.E.M. |
| physical id: | 2 |
| version: | To Be Filled By O.E.M. |
| serial: | To Be Filled By O.E.M. |
| capacity: | 90mWh |
