I’m recently switched to Linux mint mate edition i didn’t noticed to create a separate partition for my os Now it’s use my devices full space so how to split it storage like one is for personal and the another one is for system usage
Please give me the answer
press ctrl+alt+t the terminal will open then type this command sudo apt install gparted -y
ctrl+alt+t
It start install gparted. After installation Go to menu(bottom - corner window icon) → search gparted and open
gparted
Then next step
open gparted ( Go to menu(bottom - corner window icon) → search gparted and open) and sent screenshot.
The app look like this
