Hi Team,
Bluetooth is not working but wi-fi is working fine . Need your helping hand . Tried all the similar topics in " Tamillinux Community " but cant resolve sir .
Thanks,
Hi Team,
Thanks,
Please brief not working.
You mean you are not able to connect to any Bluetooth speakers or headsets ??
I couldn’t see any Bluetooth symbol to enable in the laptop sir .
Also " Bluetooth Manager " is there but if I click nothing is prompting to enable Bluetooth.
Purpose : need to connect my headset
Thanks,
bluetoothctl power on
bluetoothctl scan
bluetoothctl devices
Execute the above commands one by one and share the final screen
Note: keep your bluetooth headset powered on during this process
Thanks,
Hi,
Let’s check if your bluetooth device is blocked or not
rfkill list all
The above command should have no for both soft and hardblocked
Then try
sudo bluetoothctl show
Share the output of the both.
From this screenshot we can see not bluetooth available on your device
Let’s check hardware spec to see if any Bluetooth device present in your laptop.
lspci -nn
Run The command and share the output text. No need for screenshot. Because the text will be longer.
By the way do you know your laptop has bluetooth for sure before ??
—> Two days before bought the laptop in second hand sir , but forgot to test the Bluetooth sir.
I think with the above command we won’t be able to find bluetooth if both bluetooth and wifi on same adapter
So kindly run the below command
dmesg | grep -i blue
If the output contains “product: bluetooth” string then your computer has bluetooth
Also can you share the laptop model we can browse in the internet and double check too
Model : DELL Inspiron 3521 sir
Thanks,
No need to use sir and all
Seems Bluetooth modules are loading but not sure why product: Bluetooth is not present.
Have you tried updating drivers in the driver manager in linux mint ? If not kindly run the update
I tried all the steps I know to diagnose, but I can’t find the root cause
Some experienced linux users kindly help on this thread
lsusb -vt
இந்த தலைப்பில் எந்த ஒரு தீர்வும் இல்லாத்தால் தீர்வு எட்டப்படவில்லை என்று முடிக்கிறோம்.
