“Unresolved reference: DataFrame” in Kotlin typically arises when the compiler cannot find the DataFrame class or its associated functions. This often occurs due to missing dependencies or incorrect imports. To resolve this, one can ensure that the necessary library is added to the project and that the correct import statement is used.
Here’s how to address the issue:
- Add the Kotlin DataFrame library dependency:
- If using Gradle, add the following line to the
dependenciesblock in yourbuild.gradle.ktsfile:
தீர்வு
dependencies {
implementation(“org.jetbrains.kotlinx:dataframe:0.9.0”) // Use the latest version
- If using Maven, add the following to your
pom.xmlfile:
** org.jetbrains.kotlinx**
** dataframe**
** 0.9.0 **
தீர்வு விளக்கம்
Step 1:
install the intellij idea 2025.1 (community Edition)
creat the new project
step 2:
select the gradle or maven
step 3:
projectfilename → src->main->kotlinfolder
right click the button , new->kotlinnotebook,enter the name
step 4:
Following the dataanalysic project in the official website for kotlin kandy
Data visualization in Kotlin Notebook with Kandy | Kotlin Documentation
step 5:
ERROR:
Unresolved reference ‘dataFrameOf’.
Step 6:
• Add the Kotlin DataFrame library dependency:
◦ If using Gradle, add the following line to the dependencies block in your ----(build.gradle.kts) file:
dependencies {
implementation("org.jetbrains.kotlinx:dataframe:0.9.0") // Use the latest version
If using Maven, add the following to your pom.xml file:
<dependencies>
<dependency>
<groupId>org.jetbrains.kotlinx</groupId>
<artifactId>dataframe</artifactId>
<version>0.9.0</version> <!-- Use the latest version -->
</dependency>
</dependencies>
step 7:
copy and past the dependencies to the → build.gradle.kts file
step 8:
click the synchronic gradle changes icon.
Step 9:
it’s start the indexing process.
Step 10:
now the probleam is solved.
