I installed latest linux mint 22 in my laptop. I installed kodi through flatpak. when i try to open “kodi” it shows error like “bool” object has no attribute “get”. How to resolve this please help.
Can you install kodi with apt-get ?
https://tipsonunix.medium.com/install-kodi-20-on-ubuntu-linux-mint-a-step-by-step-guide-2d1052bb9114
https://kodi.wiki/view/HOW-TO:Install_Kodi_for_Linux
Add their PPA and install via apt.
Yes bro, i tried to install “sudo apt-get install kodi” . It installed but addons not showing
addons are called as addons because they are not default. they are to be enabled by doing something.
Did you search on how to enable addons in kodi?
I didn’t search bro, but i use the same method that works in Ubuntu 24.
In Ubuntu 24 kodi runs without any error, but i followed the same method in linux mint 22 its not working
kodi is working fine for me on linuxmint 22.
Note - with one line questions like “not working”, no one can answers.
if you dont care about explaining your issue with full details, no one can give you correct answers.
I’m following this steps to run kodi in ubuntu and linux mint 21.3 which is working . I tried the same thing in mint 22 but showing “attribute error”. Please guide me whether i have to change any settings.
Install
- Go to the Kodi file manager.
- Click on “Add source”
- The path for the source is
https://tobalan.github.io/(Give it the name “TobAlan Repo”). - Go to “Addons”
- In Addons, install an addon from zip. When it asks for the location, select “TobAlan Repository”, and install repository.tobalan-2.0.1.zip.
- Restart Kodi
- Go back to Addons install, but this time, select “Install from repository”
- Select the “Tobalan Repository”
- Go into the “Video add-ons” section in the repo, and you’ll find all video add-ons
Share the full error message.
“attribute error" ?
This information is not enough.
explain more on what addon you want and what do you want to see on kodi.
I want to install and setup jio tv in kodi. Live tv set up in kodi. After install the addons when i click jio tv and choose the language to view channels it shows these errors bro. Channels not loading. I expect to run live tv in kodi.
நான் lm 22-வில் kodi install செய்து விட்டேன். அதில் tobalan.github repo மூலம் addons enable செய்துவிட்டேன். அந்த addons - ல் எனது ஜியோ எண் வைத்து login செய்தேன். ஆனால் அதில் tv ஓடவில்லை. அதனை இயக்க முயன்ற பொழுது கீழ்காணும் error மட்டும் வருகிறது
முந்தைய addon ல் பிழை உள்ளது.
பின்வரும் இணைப்பில் உள்ள addon ஐ நிறுவினேன்.
jiotv addon வேலை செய்கிறது.
அதற்கு உள்ளே போனால் login கேட்கிறது.
login செய்ய முடிகிறது.
ஆனால், பிழை வருகிறது. நிரலில் உள்ள jiotv சர்வர் இடம் இருந்து பதில் ஏதும் வரவல்லை. எனவே இதுவும் பயனில்லை.
அடுத்து GitHub - henry-richard7/JioTV-Proxy: JioTV proxy developed using Python and FastAPI framework. முயன்றேன்.
இங்குள்ள பிழை வருகிறது.
அவர்கள் அதை சரி செய்ய நேரமில்லை என்று ஒதுங்கி விட்டார்கள்.
அவர்கள் சொன்னபடி, அடுத்து, JioTV GO https://jiotv_go.rabil.me/usage/linux-macos.html
முயன்றேன்.
அதில் login செய்தால், channel பட்டியல் கிடைக்கிறது.
ஆனால் காணொளிகளை இயக்கினால், பிழை வருகிறது.
அவர்களது டெலிகிராம் குழுவில் கேட்டுள்ளேன்.
ஏதாவது தீர்வு கிடைக்கிறதா என்று பார்ப்போம்.
நன்றி சகோ. பதிலுக்காக காத்திருக்கிறேன்.
