often I have face it.
Close all the eclipse tab then open eclipse newly
If not solve. Then sent photo of your screen
workspace allocate agamatenguthu…
Thiruba Thiruba intha pirachanai varuthu…
ipokoda kekuthu
screen shot anupuran parunga
How many eclipse workspaces you created. Check it. Because you already create a workspace in that path.
Bro… First default ulla path ahh than launch panna naan… but apovum ithu Pola than error vanthuchu…
Athanala tha Naa own create panna… but
athukku ithu Pola than msg vanthuchu
ipo enaku oru solution than venum
epidi itha solve pannalam solluga…
please
Bro,
You are open eclipse muilt-times. So that you are got this error.
Solution:
just click close button (on the rigth-top corner) in that error message window.
image delete pannitunga
No bro
இந்த சிக்கல் தொடர்கின்றதா?
No bro…
This is the solution
இந்த தலைப்பில் நீண்ட நாட்களாக எந்த ஒரு விவாதமும் நடைபெறாததால் தீர்வு எட்டப்படவில்லை என்று முடிக்கிறோம்.
