Not properly load emacs config.org file
bro na emacs flatpak la irundu emacs debian ku mathunan
ippo emacs config.org load aguthu but full la aagala custom keybinds work panala like register,ibuffer
emacs version
27.1
emacs init.el file
(org-babel-load-file
 (expand-file-name
  "config.org"
  user-emacs-directory))
(custom-set-variables
 ;; custom-set-variables was added by Custom.
 ;; If you edit it by hand, you could mess it up, so be careful.
 ;; Your init file should contain only one such instance.
 ;; If there is more than one, they won't work right.
 '(package-selected-packages
   '(ef-themes which-key visual-fill-column vertico use-package rainbow-delimiters orderless nov marginalia helpful emms doom-themes doom-modeline consult)))
(custom-set-faces
 ;; custom-set-faces was added by Custom.
#+title: My Configuration
#+author: Thanga Ayyanar
#+startup: overview
* User Interface
** Hide menubar
#+begin_src emacs-lisp
(menu-bar-mode 0)
** Hide toolbar and scrollbar
;(when (display-graphic-p)
  (tool-bar-mode 0)
  (scroll-bar-mode 0);)
** No inhibit startup message
(setq inhibit-startup-screen t)
** Set number
(column-number-mode)
(global-display-line-numbers-mode t)
** Theme
(use-package ef-themes
:config
(load-theme 'ef-dark t))
** Font configuration
(set-face-attribute 'default nil :font "Liberation Mono" :height 200)
* Behavior
** No (backup, Lock, autosave)
;; No autoback up and lock files
(setq
 make-backup-files nil
 auto-save-default nil
 create-lockfiles nil)
** Y or N instead of Yes or No
(fset 'yes-or-no-p 'y-or-n-p)
** Electric auto pair mode
(electric-pair-mode 1)
** Turn off blinking cursor
  ;(blink-cursor-mode -1)
** Vertical bar
(setq-default cursor-type 'bar)
** Auto revert
- Auto revert Files
#+begin_src elisp
  (global-auto-revert-mode 1)
- Auto revert Directory
#+begin_src elisp
  (setq global-auto-revert-non-file-buffers t)
- Auto revert issues i faced
#+begin_src elisp
  (add-to-list 'global-auto-revert-ignore-modes 'Buffer-menu-mode)
** Registers
#+begin_src elisp
  ;; Registers
  (set-register ?I '(file . "/home/linux/.emacs.d/config.org")) ;; C-x r j E
  (set-register ?T '(file . "/home/linux/.config/i3/config")) ;; C-x r j T
** Buffers
*** Buffer switching
#+begin_src elisp
  (global-set-key [(meta shift j)] 'previous-buffer)
  (global-set-key [(meta shift l)] 'next-buffer)
*** Buffer kill
#+begin_src elisp
  (global-set-key (kbd "C-x K") 'kill-this-buffer)
*** iBuffer
#+begin_src elisp
  (global-set-key (kbd "C-x C-b") 'ibuffer)
  ; Ibuffer options
(setq ibuffer-saved-filter-groups
  (quote (("default"
  ("dired" (mode . dired-mode))
  ("org" (name . "^.*org$"))
  ;; ("web" (or (mode . web-mode) (mode . js2-mode)))
  ("shell" (or (mode . eshell-mode) (mode . shell-mode)))
  ;; ("mu4e" (name . "\*mu4e\*"))
  ;; ("programming" (or
  ;; (mode . python-mode)
  ;; (mode . c++-mode)))
  ("emacs" (or
  (name . "^\\*scratch\\*$")
  (name . "^\\*Messages\\*$")))
(add-hook 'ibuffer-mode-hook
  (lambda ()
  (ibuffer-auto-mode 1)
  (ibuffer-switch-to-saved-filter-groups "default")))
;; Don't show filter groups if there are no buffers in that group
(setq ibuffer-show-empty-filter-groups nil)
;; Don't ask for confirmation to delete marked buffers
(setq ibuffer-expert t)
* Use package
** Installation
(require 'package)
(setq package-archives '(("melpa" . "https://melpa.org/packages/")
			("org" . "https://orgmode.org/elpa/")
			("elpa" . "https://elpa.gnu.org/packages/")))
(package-initialize)
(unless package-archive-contents
  (package-refresh-contents))
;; Initialize use package on non-linux based system
(unless (package-installed-p 'use-package)
  (package-install 'use-package))
(require 'use-package)
(setq use-package-always-ensure t)
* Third party packages
** Which Key
(use-package which-key
:init (which-key-mode)
:diminish which-key-mode
:config
(setq which-key-idle-delay 0.3))
** Helpful
(use-package helpful
  :commands (helpful-callable helpful-variable helpful-command helpful-key)
  :bind
  ([remap describe-function] . helpful-callable)
  ([remap describe-command] . helpful-command)
  ([remap describe-variable] . helpful-variable)
  ([remap describe-key] . helpful-key))
** DooM modeline
(use-package doom-modeline
  :init (doom-modeline-mode 1))
** Nerd icons
(use-package nerd-icons
  ;; :custom
  ;; The Nerd Font you want to use in GUI
  ;; "Symbols Nerd Font Mono" is the default and is recommended
  ;; but you can use any other Nerd Font if you want
  ;; (nerd-icons-font-family "Symbols Nerd Font Mono")
** Doom themes
(use-package doom-themes
  :config
  ;; Global settings (defaults)
  (setq doom-themes-enable-bold t    ; if nil, bold is universally disabled
        doom-themes-enable-italic t) ; if nil, italics is universally disabled
  (load-theme 'doom-one t)
    ;; Enable custom neotree theme (all-the-icons must be installed!)
  ;;(doom-themes-neotree-config)
  ;; or for treemacs users
  ;;(setq doom-themes-treemacs-theme "doom-atom") ; use "doom-colors" for less minimal icon theme
  ;;(doom-themes-treemacs-config)
  ;; Corrects (and improves) org-mode's native fontification.
  (doom-themes-org-config))
** Completion
  ;; Enable vertico
  (use-package vertico
    :init
    (vertico-mode)
    ;; Different scroll margin
    ;; (setq vertico-scroll-margin 0)
    ;; Show more candidates
    ;; (setq vertico-count 20)
    ;; Grow and shrink the Vertico minibuffer
    ;; (setq vertico-resize t)
    ;; Optionally enable cycling for `vertico-next' and `vertico-previous'.
    (setq vertico-cycle t)
  ;; Persist history over Emacs restarts. Vertico sorts by history position.
  (use-package savehist
    :init
    (savehist-mode))
  ;; Optionally use the `orderless' completion style.
  (use-package orderless
    :init
    ;; Configure a custom style dispatcher (see the Consult wiki)
    ;; (setq orderless-style-dispatchers '(+orderless-consult-dispatch orderless-affix-dispatch)
    ;;       orderless-component-separator #'orderless-escapable-split-on-space)
    (setq completion-styles '(orderless basic)
	  completion-category-defaults nil
	  completion-category-overrides '((file (styles partial-completion)))))
  ;; Enable rich annotations using the Marginalia package
  (use-package marginalia
    ;; Bind `marginalia-cycle' locally in the minibuffer.  To make the binding
    ;; available in the *Completions* buffer, add it to the
    ;; `completion-list-mode-map'.
    :bind (:map minibuffer-local-map
	   ("M-A" . marginalia-cycle))
    ;; The :init section is always executed.
    :init
    ;; Marginalia must be activated in the :init section of use-package such that
    ;; the mode gets enabled right away. Note that this forces loading the
    ;; package.
    (marginalia-mode))
** Rainbow delimters
(use-package rainbow-delimiters
  :hook (prog-mode . rainbow-delimiters-mode))
** consult
;; Example configuration for Consult
(use-package consult
  ;; Replace bindings. Lazily loaded due by `use-package'.
  :bind (;; C-c bindings in `mode-specific-map'
         ("C-c M-x" . consult-mode-command)
         ("C-c h" . consult-history)
         ("C-c k" . consult-kmacro)
         ("C-c m" . consult-man)
         ("C-c i" . consult-info)
         ([remap Info-search] . consult-info)
         ;; C-x bindings in `ctl-x-map'
         ("C-x M-:" . consult-complex-command)     ;; orig. repeat-complex-command
         ("C-x b" . consult-buffer)                ;; orig. switch-to-buffer
         ("C-x 4 b" . consult-buffer-other-window) ;; orig. switch-to-buffer-other-window
         ("C-x 5 b" . consult-buffer-other-frame)  ;; orig. switch-to-buffer-other-frame
         ("C-x r b" . consult-bookmark)            ;; orig. bookmark-jump
         ("C-x p b" . consult-project-buffer)      ;; orig. project-switch-to-buffer
         ;; Custom M-# bindings for fast register access
         ("M-#" . consult-register-load)
         ("M-'" . consult-register-store)          ;; orig. abbrev-prefix-mark (unrelated)
         ("C-M-#" . consult-register)
         ;; Other custom bindings
         ("M-y" . consult-yank-pop)                ;; orig. yank-pop
         ;; M-g bindings in `goto-map'
         ("M-g e" . consult-compile-error)
         ("M-g f" . consult-flymake)               ;; Alternative: consult-flycheck
         ("M-g g" . consult-goto-line)             ;; orig. goto-line
         ("M-g M-g" . consult-goto-line)           ;; orig. goto-line
         ("M-g o" . consult-outline)               ;; Alternative: consult-org-heading
         ("M-g m" . consult-mark)
         ("M-g k" . consult-global-mark)
         ("M-g i" . consult-imenu)
         ("M-g I" . consult-imenu-multi)
         ;; M-s bindings in `search-map'
         ("M-s d" . consult-find)
         ("M-s D" . consult-locate)
         ("M-s g" . consult-grep)
         ("M-s G" . consult-git-grep)
         ("M-s r" . consult-ripgrep)
         ("M-s l" . consult-line)
         ("M-s L" . consult-line-multi)
         ("M-s k" . consult-keep-lines)
         ("M-s u" . consult-focus-lines)
         ;; Isearch integration
         ("M-s e" . consult-isearch-history)
         :map isearch-mode-map
         ("M-e" . consult-isearch-history)         ;; orig. isearch-edit-string
         ("M-s e" . consult-isearch-history)       ;; orig. isearch-edit-string
         ("M-s l" . consult-line)                  ;; needed by consult-line to detect isearch
         ("M-s L" . consult-line-multi)            ;; needed by consult-line to detect isearch
         ;; Minibuffer history
         ("M-s" . consult-history)                 ;; orig. next-matching-history-element
         ("M-r" . consult-history))                ;; orig. previous-matching-history-element
  ;; Enable automatic preview at point in the *Completions* buffer. This is
  ;; relevant when you use the default completion UI.
  :hook (completion-list-mode . consult-preview-at-point-mode)
  ;; The :init configuration is always executed (Not lazy)
  :init
  ;; Optionally configure the register formatting. This improves the register
  ;; preview for `consult-register', `consult-register-load',
  ;; `consult-register-store' and the Emacs built-ins.
  (setq register-preview-delay 0.5
        register-preview-function #'consult-register-format)
  ;; Optionally tweak the register preview window.
  ;; This adds thin lines, sorting and hides the mode line of the window.
  (advice-add #'register-preview :override #'consult-register-window)
  ;; Use Consult to select xref locations with preview
  (setq xref-show-xrefs-function #'consult-xref
        xref-show-definitions-function #'consult-xref)
  ;; Configure other variables and modes in the :config section,
  ;; after lazily loading the package.
  :config
  ;; Optionally configure preview. The default value
  ;; is 'any, such that any key triggers the preview.
  ;; (setq consult-preview-key 'any)
  ;; (setq consult-preview-key "M-.")
  ;; (setq consult-preview-key '("S-<down>" "S-<up>"))
  ;; For some commands and buffer sources it is useful to configure the
  ;; :preview-key on a per-command basis using the `consult-customize' macro.
  (consult-customize
   consult-theme :preview-key '(:debounce 0.2 any)
   consult-ripgrep consult-git-grep consult-grep
   consult-bookmark consult-recent-file consult-xref
   consult--source-bookmark consult--source-file-register
   consult--source-recent-file consult--source-project-recent-file
   ;; :preview-key "M-."
   :preview-key '(:debounce 0.4 any))
  ;; Optionally configure the narrowing key.
  ;; Both < and C-+ work reasonably well.
  (setq consult-narrow-key "<") ;; "C-+"
  ;; Optionally make narrowing help available in the minibuffer.
  ;; You may want to use `embark-prefix-help-command' or which-key instead.
  ;; (define-key consult-narrow-map (vconcat consult-narrow-key "?") #'consult-narrow-help)
  ;; By default `consult-project-function' uses `project-root' from project.el.
  ;; Optionally configure a different project root function.
  ;;;; 1. project.el (the default)
  ;; (setq consult-project-function #'consult--default-project--function)
  ;;;; 2. vc.el (vc-root-dir)
  ;; (setq consult-project-function (lambda (_) (vc-root-dir)))
  ;;;; 3. locate-dominating-file
  ;; (setq consult-project-function (lambda (_) (locate-dominating-file "." ".git")))
  ;;;; 4. projectile.el (projectile-project-root)
  ;; (autoload 'projectile-project-root "projectile")
  ;; (setq consult-project-function (lambda (_) (projectile-project-root)))
  ;;;; 5. No project support
  ;; (setq consult-project-function nil)
** Nov - epub reader
  (use-package visual-fill-column)
  (use-package nov
      :defer t
      :init
      (add-to-list 'auto-mode-alist '("\\.epub\\'" . nov-mode))
      :config
      (setq nov-text-width t)
      (setq visual-fill-column-center-text t)
      (add-hook 'nov-mode-hook 'visual-line-mode)
      (add-hook 'nov-mode-hook 'visual-fill-column-mode)
** EMMS - MPV player integration
(use-package emms
  :config
    (emms-all)
    (setq emms-player-list '(emms-player-mpv)
	emms-info-functions '(emms-info-native)))
** Denote
;(use-package denote
;  :custom
;  (denote-directory "~/Notes"))
* Load Custom Elisp files
** Tell me how much time it takes to load configuration
;;(add-hook 'emacs-startup-hook
;;          (lambda ()
;;            (message "Emacs loaded in %s."
;;                     (emacs-init-time))))
* Inbuild programs
** Newsticker - RSS feed reader
(setq newsticker-url-list `(
("Kaniyam Foundation" "https://www.kaniyam.com/feed/" nil 3600)
("Julia Evans" "https://jvns.ca/atom.xml" nil 3600)
Okay can you check whether there is any error message in ‘message’ buffer
press C-x b and select message buffer
restart emacs and see this buffer
ennaku theriyala bro any error irukanu sollunga please
Loading /etc/emacs/site-start.d/00debian.el (source)…done
Loading /etc/emacs/site-start.d/50dictionaries-common.el (source)…
Loading debian-ispell…
Loading /var/cache/dictionaries-common/emacsen-ispell-default.el (source)…done
Loading debian-ispell…done
Loading /var/cache/dictionaries-common/emacsen-ispell-dicts.el (source)…done
Loading /etc/emacs/site-start.d/50dictionaries-common.el (source)…done
Loading /home/linux/.emacs.d/config.el (source)…done
Loaded /home/linux/.emacs.d/config.el
For information about GNU Emacs and the GNU system, type C-h C-a
Seems like everything loaded properly. What happen when you press C-x r j
na 2 file add panirukan(config.org, i3config) but not display
What happen when you press capital I or T after C-x r j ? Yeah nothing is previewed. Just try pressing the key let me know what happens.
Also check the message buffer after this for any errors.
na venna init.el file top and end message add pani pakava bro
May be this syntax is not available in emacs 27 i guess.
copy the set register commands to scratch buffer
Then press Alt+x eval-buffer
And then try C-x r j and your shortcut
na config.org file la manuval la ctrl+x ctrl+e kuduthu run panna work panudu bro sorry na indha mudaliya solli irukanum
before
after
Then something in the config.org file is failing so the code after that is not executed.
I donot know why you are interested in older emacs. May i know why ?
bro flatpak la thaniya oru container la run panudu
so
emacs shell(not eshell) la silla command run aaga matikidu ( go run file.go, npm start)
idha command lam pootta shell la command not found nu varudu
so mohan anna debian version use panunga nu sonnaru
anna init.el file kodutharu nalla work panuchi.
ennaku palaiya customize la set aaiduchi (ibuffer,theme,register,etc) so na old config load pannan. theme lam load aaguthu but full la load aagala thats my problem:(
Okay what happen when you move the set register command to the init.el
and restart the emacs
is the register shortcut available now ?
bro init.el la na type pannadu
 (expand-file-name
  "config.org"
ivalow dhan
register command la enaku init.el la poda theriyadu bro:(
bro config.el file share panna va?
Copy line starts with (set-register, to top of the init.el file above (org babel, command
(set-register ?I '(file . “/home/linux/.emacs.d/config.org”)) ;; C-x r j E
(set-register ?T '(file . “/home/linux/.config/i3/config”)) ;; C-x r j T
(expand-file-name
“config.org”
;; If there is more than one, they won’t work right.
(custom-set-faces
correct ta bro?
ippo register work panudu bro
I will go through your config.org in my free time and let you know
okay bro. no problem bro :slight_smile:
ongalo da config.org part8 dha bro use panran
config.org part 8
