![image|500x122](upload://gpC9jGkLpoowUkIoE1xhZEivM4k.png
Earlier with VMware based - launching of docker didn’t throw this error.
While performing on base: LINUX distro: Parrot OS - below problem is faced:
Docker has returned an error: Cannot connect to unix socket /var/run/docker.sock ssl:default [Permission denied]
Kindly confirm if any known remedy to fix above problem ( I have tried restarting the docker instance and followed steps referred with forums answering docker problems.
sudo apt-get install docker-ce ==========> when performing with referred remedy: docker-ce and docker-ce-cli were not installable with parrot OS. please check are you able to install in other distros of DEBIAN OS.
