during the problematic time, i am not able to even ping my gateway IP. Traceroute towards the gateway IP is routed towards the local IP.
[sasikumar@fedora ~]$ netstat -nr
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 wlp3s0
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 wlp3s0
[sasikumar@fedora ~]$ ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
From 192.168.0.104 icmp_seq=1 Destination Host Unreachable
From 192.168.0.104 icmp_seq=2 Destination Host Unreachable
From 192.168.0.104 icmp_seq=3 Destination Host Unreachable
From 192.168.0.104 icmp_seq=4 Destination Host Unreachable
^C
— 192.168.0.1 ping statistics —
4 packets transmitted, 0 received, +4 errors, 100% packet loss, time 3086ms
pipe 3
[sasikumar@fedora ~]$ traceroute 192.168.0.1
traceroute to 192.168.0.1 (192.168.0.1), 30 hops max, 60 byte packets
1 fedora (192.168.0.104) 2741.148 ms !H 2741.123 ms !H 2741.119 ms !H
when i flush the mac address filter on the router
64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=49.0 ms
64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=9.18 ms
64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=5.20 ms
64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=5.51 ms
64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=15.0 ms
^C
5 packets transmitted, 5 received, 0% packet loss, time 4022ms
rtt min/avg/max/mdev = 5.199/16.760/48.955/16.476 ms
1 _gateway (192.168.0.1) 13.139 ms 13.090 ms 13.076 ms
even i tested & found this behavior with fresh fedora 36 installation
