After the completion of linux mint install how to connect my mobile hotspot and check your video driver that notification come at every time
And touchpad also enable but not workings sir
First of all, After a fresh OS installation.
Please do a system update.
Have you tried updating your system ?
After updating your system, if you still face the wifi issues. Please run below command in linux terminal and share the output.
lspci
Run The below command and show the output
rfkill list
Let’s check if the wifi drivers are loaded or not
Please execute the bellow command and share the output.
lspci -s 01:00.0 -nnk
Seems no proper driver is loaded in.
Please follow the below video guide on how to install drivers.
Make sure you connected to internet through ethernet or usb tethering so the wifi drivers can be searched and installed.
Wifi not showing still any one help me
Were you connected to the internet through lan or usb tethering while checking for updates ?
If so, again run this command and shre the output
Please share output of the below command
cat /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Execute the below command and post execution restart your machine and check if wifi is working.
sudo sed -i 's/3/2/' /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
No OUTput
It won’t show anything, after restarting are you able to get wifi?
Already restart it sir …stll not showing the wifi connection sir
