i’m using ubunut 22.04, my laptop has 4gb ram, while start-up booting is very slow, how to increase booting time. please help…
Slow means how much slow?
How many hours it takes to get into login screen?
What desktop environment you use?
Once logged in, run the below command and share the result.
sudo netstat -ltnp
It will list the running services. We can check and disable any unwanted services.
bro “sudo netstat -ltnp” while i run the command it shows that “command not found”
Search how to install netstat in Ubuntu and install it.
Answer my all questions above.
இந்தப் பதிவில் உங்களுக்குத் தேவையானவை இருக்கலாம், பாருங்கள்
