Can you share more info on this ?
Because without specifics we cannot find the root cause
By which source are you trying to install kdenlive ?
(Is it through apt or deb package from website or compiling from source code ?)
yes
ppa add panitu install panna anna
Again you are not saying from which source you are trying to install ?
From above screenshot i can see some dependencies are missing first try to install those and continue with kdenlive installation
sudo apt install kdenlive
indha command dha bro pootan
Seems the issue is your linux distro already have the melt and libmlt version.
So kdenlive tries to update them but fails to update it properly.
You can remove the melt and libmlt firstly
Then do a kdenlive install.
If you already installed the kdenlive improperly ten try to clean remove it firstly
Found this from reference
Run the below commands one by one
Below commands remove incorrectly installed kdenlive
sudo apt purge kdenlive
Below one removes issues old version libmlt and melt
sudo apt purge libmlt7-data melt
Again reinstalling kdenlive properly
This should solve the issue
Try and reply
ls -l /etc/apt/sources.list.d
cat /etc/apt/sources.list.d/kdenlive-kdenlive-stable-jammy.list
ls -ltr /var/lib/apt/lists/ppa*_Packages
grep '^Package:' /var/lib/apt/lists/ppa.*_Packages | cut -d' ' -f2- | xargs dpkg -l 2>/dev/null | grep '^ii' | awk '{print $2}' | cut -d: -f1
sudo apt purge -y kdenlive-data libmlt++7 libmlt7
இந்த கமாண்டை இயக்கவும். முடிந்தபின்
இந்த கமாண்டை இயக்கவும். வரும் தகவலை பகிரவும்.
sudo apt --fix-broken install
இந்த கமாண்டை இயக்கிய பின்
