hi linux users
na emacs editor la
init.el and
config.org
2 files create panitan
but
config file load panna matikidu
hi linux users
na emacs editor la
init.el and
config.org
but
Can you type Alt+x and type ielm
Once it is opened, type user-emacs-directory and share your result.
Also i like to know where the config.org file is saved, share the absolute file path of the file
eg: For me the config.org file is store inside the .emacs.d/config.org
Okay nice
can you type this command in ielm (Alt+x and type ielm)
(org-babel-load-file (expand-file-name "config.org" user-emacs-directory))
What is version of emacs you are using ?
you can find this using
Alt+x emacs-version
27.1
* Basic Configuration
** User Interface
*** Hide menubar
#+begin_src emacs-slip
(menu-bar-mode 0)
*** Hide Toolbar and Scrollbar
(when (display-graphic-p)
(tool-bar-mode 0)
(scroll-bar-mode 0))
*** No inhibit startup message
(setq inhibit-startup-screen t)
*** set number
(column-number-mode)
(global-display-line-numbers-mode t)
*** Theme
(load-theme 'wombat)
*** Font Configuration
** Behavior
*** No (Backup, Lock, Autosave)
(setq
make-backup-files nil
auto-save-default nil
create-lockfiles nil)
*** Y or N instead of Yes or No
(fset 'yes-or-no-p 'y-or-n-p)
The begin_src block should be emacs-lisp or elisp not emacs-slip
can you try changing the all the blocks language and try again
emacs replace keybind sollunga bro
Move the cursor to the begining of the file and do the following
press Alt+% (Alt + Shift + 5) and then type slip and lisp,
Once you are in replace mode then press ! (Shift + 1) which will replace all the occurance
Super, save the file and restart emacs
save panitu
emacs close pani
open pannan bro
no changes:(
Can you check the changes are saved in the file ?
