can you try this again and post the screen shot
Seems like it worked ![]()
new va open panna config load aagala bro
Can you share the screen shot for newly opened emacs ?
Can you check, is your init.el file has proper code ?
Can you open the Messages buffer and post its screen shot need to check for any error while loading config ?
to open Messages buffer, Ctrl+x b and type *Messages* (including *) and enter
Seems like init.el file is not loaded ![]()
(message "Hello from init")
(org-babel-load-file
(expand-file-name
"config.org"
user-emacs-directory))
(message "Init file ends here")
replace the contents of init.el file with above code and post screenshot of *Messages* buffer
have you restarted the emacs after init.el file changes, if not can you do it and post the new screenshots ?
no bro
first init.el file edit pannan
after open emacs and shared buffer screenshot
Ohh, seems like the init.el file is not loaded by emacs.
eppiti bro load panradu?
Do you have any .emacs file in the home directory ?
post what is in the .emacs file ?
