If the .emacs is not necessary, delete the file and restart the emacs
mass bro
work panudu bro
thanks bro
again one doubt bro
eppiti bro font mathuradu “free sans regular” font ku
(set-face-attribute 'default nil :font "FONT" :height 150)
Use the proper font name for above, instead of FONT
(set-face-attribute 'default nil :font "FreeSans" :height 150)
This worked for me, adjust the height to your liking
You can get the Font name from Fonts software
thanks bro ![]()
font change panitan
na innimal emacs user bro
Mass
bro one doubt init.el file la irukkura
(message "Hello from init")
(message "Init file ends here")
inda 2 line remove panitava?
Yes you can remove it
okay bro
thanks bro ![]()
I am using emacs version 29.1 for demo and tutorials, you can download the latest from flatpak or compile from source as the default emacs package from ubuntu, debain store is oudated.
okay bro ![]()
thanks bro enakkaga time spend pannaduku ![]()
No problem ![]()
